The Virtual DJ 6 demo can be download here:
https://virtualdj.com/download/trial.html
If you think about 2 Installations -> that will work, you have only install the 2 Virtual DJ Version in 2 different locations.
For example Version 5.2.1 in C:\Programms\VirtualDJ\
Version 6.0.1 in C:\Programms\VirtualDJ6\
so you can run both versions :)
geposted Wed 10 Jun 09 @ 6:11 am
You are better off renaming the v5 version to somethin like virtualdj5.exe, and then just simply installing V6 as normal.
geposted Wed 10 Jun 09 @ 1:56 pm
