I finally got VDJ 6.0 to work but when I wanted to record, it says "Record Error" and below it it says "Can't open MP3 Encoder." I never had this problem with VDJ 5.0. Here is what my CONFIG is:
Record From: Master
File: C:\Documents and Settings\my|Desktop|test.mp3
Box checked for "Prompt if overwrite"
Format: MP3
Encoder: C:\PROGRA~1\VIRTUA~1\lame_enc.dll
Bitrate: 256kbs
How can I rectify this problem?
By the way thanks for all of your help, you guys have been great in responding!
Record From: Master
Format: MP3
Bitrate: 256kbs
geposted Wed 10 Jun 09 @ 11:26 am
Had the same trouble in vers. 5. Your encoder probably got corrupted. If you want to send your email addy in a private, I'll send you the file.
geposted Wed 10 Jun 09 @ 2:49 pm
djnrgbear:
Thanks, I sent you a private message with my email address. Thanks very much for your help!
geposted Wed 10 Jun 09 @ 4:15 pm
hey guys I have some problem over here
When I try to record Master + mic it is impossible .... "Record Error" unavailable soundcard
I'm using VDJ 6.0.1 and Hercules RMX
BTW If I'm recording only master there's no problem......
any help ......
any help ......
geposted Fri 12 Jun 09 @ 6:15 am
hi djnrgbear,saw your reply about the corrupted encoder,also having the same problem,can you pls send me the encoder file,here is my email add ***@yahoo.com thanks a bunch....
(Sorry, contact details are not allowed from unlicensed users.)
geposted Thu 06 Aug 09 @ 2:36 am
