ok guys decided to do a fresh download of both vdj 6.1 and hercules drivers.what do i need to do to completley remove vdj 6.1 od all xml for that programme only as i have two other versions of vdj that im keeping thanks
geposted Thu 11 Jun 09 @ 7:27 am
Why could you not use your other post for this question?
And to answer what you need to do is in the Hardware forum ... but I will retype here ...
1. Uninstall v6
2. Uninstall Hercules drivers
3. Reboot
4. Download latest Hercules drivers and install
5. Download v6.0.1 from your Download Center and install
6. Reboot
Open VirtualDJ and configure your system...
1. Uninstall v6
3. Reboot
6. Reboot
geposted Thu 11 Jun 09 @ 7:46 am
sorry cstoll for the multiple posts.but in my add remove area on pc there is only 1 vdj programme.i want to keep my other versions.and only one vdj folder in my documents
geposted Thu 11 Jun 09 @ 7:50 am
If you renamed the other virtualdj.exe files for the other versions, don't worry about it .. they will not get deleted from the uninstall. Also, the 'key' files like database files are not removed either by the uninstall.
geposted Thu 11 Jun 09 @ 8:56 am
ok mate thank you.ill delete all even xml from 6.1 and do full reinstall
geposted Thu 11 Jun 09 @ 11:20 am
