I have my spacebar set as a play/stutter button. when I load a video into the player and hit the stutter key multiple times, the video then freezes and jumps back and forth for maybe 1 frame or so, and then it moves on. the video and audio are in sync, but just the first few seconds of the cue point that I started the track at stutter.
I am using a dell xps 1710, with no problems like this in the previous version. This is only happening in the updated version.
Anybody else experiencing this?
Anybody have a fix?
Anybody have a fix?
geposted Thu 11 Jun 09 @ 5:52 pm
If it's an nVidia chipset ... go download the Registry Tool from the Tools/Drivers download area .. run it and put a check in the nVidiaFix box.
Also, go to the Performance tab and uncheck the Safemode (if checked) and see if that helps.
geposted Thu 11 Jun 09 @ 9:39 pm
Thanks chris, I'll give it a go to tomorrow. By the way, the windows reinstall went spectacular. Thanks!
geposted Mon 22 Jun 09 @ 12:49 am
no dice, even after I check the option in the registry tool. Also, the audio of the music videos is not in sync.
I wonder, is there a way to download the previous version of VDJ? I didn have any problems with that one.
geposted Tue 23 Jun 09 @ 12:41 pm
