Does anyone know how well the Rane TTM 56S mixer works with VDJ?
geposted Thu 11 Jun 09 @ 6:42 pm
I know it works but I just want to know if anyone does use the Rane TTM 56s or if I should go with something else? Just want to get some feedback so I can figure out what the best route to go. I know I want something is stable, last long, and is the best for scratching.
geposted Thu 11 Jun 09 @ 6:50 pm
the ttm56s is made from the same chassis as the ttm57sl, but without the built in asio interface, effect bank and controll unit for the ssl software.
it is a rock solid mixer with the best faders available. but if you can get an ttm56 (without S) than take one of these. the old model has better fader curve options.
geposted Thu 11 Jun 09 @ 7:12 pm
Another question would be how well will the ttm56 work with Virtual Vinyl since I will be getting Virtual Vinyl soon. I'm just curious if there would be any configuration problems if I do get the mixer and use Virtual Vinyl. If there are any configuration problems at the start what would they be and if there any solutions to fix these problems. I'm figuring if there are better options to go with since I don't want to go through frustrations and pick the wrong equipment
geposted Thu 11 Jun 09 @ 8:04 pm
the ttm56/56s is a ordinary audio mixer. there is no "configuration" with vdj/vv/cue. it works like any other audio mixer.
geposted Thu 11 Jun 09 @ 8:53 pm
