Hi there!
I haven't found an other skin that got the same possability's as the TASCAM skin. The problem is that I don't understand anything of the XML files. My knowledge is too less.. :(
- In 1 touch, you can hit 1/4 til 64 loops
- Jogwheel works as pitchbend
- NOT to much buttons, so the overview stays nice
The new standard skin of the v6 is pretty good, but I don't want to pitchbend with the arrow-buttons underneath the pitchfader, but with the jogwheel. But unfortunatly that function issn't working in 98% of all the skins that are available. And at the skins that does, the pitchbend function doesn't work on the jogwheel with v6.
Please, can you help me or do you know someone who can make me a custom skin. I'm willing to pay for it!
Greetz,
Robin
Greetz,
Robin
geposted Thu 11 Jun 09 @ 11:48 pm
right click + drag on a 'jog' and it will pitch bend on most skins
(just that the jog is usually too sensitive by default).
geposted Fri 12 Jun 09 @ 8:11 am
Thanks for the submit, but that's just not accurate as it should we.
When you've got both channels running and you want to adjust 1 during the play, it just issn't accurate enough.
Why ain't it possible to switch the jogwheel function from scratch to pitchbend like the real Pioneers CDJ-800/1000?
geposted Fri 12 Jun 09 @ 9:51 am
It is, but skin designers did not include that possibility in most of the skins,
you can however do it yourself by opening a skin's .xml file, and replace the
'scratch' action to 'nudge' (i think) on both decks' jog elements.
geposted Sat 13 Jun 09 @ 3:25 am
