I've tried over and over and still not getting this to work. However, this did work, but is not what I'm wanting.
Shift+D 0%
Shift+L 100%
Those worked, but I do not want to have to push Shift to get this to work. Hmmmmmm. Still curious what's wrong with simply having...
d 0%
l 100%
Weird why it works with Shift and not as a lower case letter. Also, what do I add for momentary?
Shift+D 0%
Shift+L 100%
d 0%
l 100%
geposted Wed 22 Jul 09 @ 3:15 pm
Shift+D 0%
Shift+L 100%
d 0%
l 100%
Shift+D 0%
Shift+L 100%
d 0%
l 100%
I had simmilar "problem" with the shift+ commands thus why i posted the theory with it not recognizing lower case letters.. i also belive if you are having to use the shift+ there are other commands linked to the letter you are trying to use, look through the list and see if there is anything else assigned to "D" and "L", if so remove them or change the letters and i bet it'll work... I FULLY SUPPORT VDJ AS THE BEST THERE IS FOR LIVE MIXING, HANDS DOWN THE BEST.. no question about it...
anyway i hope you find my info helpfull and solve your issue.. T
geposted Wed 22 Jul 09 @ 8:52 pm
I would definitely start hunting for duplicates, elite1...sounds like a conflict. For example, in the default keyboard mapper, CTRL+PGDN is crossfader 0%, and CTRL+PGUP is crossfader 100%. This might be causing problems with your shortcuts.
Also, if 0% was full right and 100% full left, instead of the other way around, you might have had crossfader_hamster set somehow.
geposted Wed 22 Jul 09 @ 10:58 pm
for momentary you probably want while_pressed...
geposted Thu 23 Jul 09 @ 1:04 pm
I'm not sure you can use this with the keyboard because the keys repeat, but, admittedly, I've never tried it.
geposted Fri 24 Jul 09 @ 7:41 pm
Hi, I'm having the exact problem. Is there someone I can contact, so that my shortcuts can be converted?
geposted Thu 03 Sep 09 @ 8:00 pm
How can I set a shortcut key (Octaves) to go continuously from 0 to 100 ? Can anyone help me please? thanks
geposted Sun 15 Dec 13 @ 9:33 am
