hey guys I have some problem over here
When I try to record Master + mic it is impossible .... "Record Error" unavailable soundcard
I'm using VDJ 6.0.1 and Hercules RMX
BTW If I'm recording only master there's no problem......
All Updated ...
any help ......
All Updated ...
any help ......
geposted Sat 13 Jun 09 @ 1:27 pm
First you have to know that this will not work if the Rmx is used in ASIO mode, so check your configuration as follow:
a) In the Rmx Control panel, for INPUT CHANNEL 1/2, be sure to select MIC
b) In Virtual DJ Sound Setup, DJ CONSOLE RMX should be selected as Sound card. Make sure the box for "APPLY EQ..." is NOT checked. This will insure that the Rmx is used in WDM mode.
c) In the Record Audio config, in the menu that appear when you choose MASTER + MIC , Select "LINE" (Hercules DJ Console Rmx)
You should now be able to record both music and microphone.
geposted Mon 15 Jun 09 @ 8:20 am
hmmm thanks mate, I'll try it tonight
as I remember my problem might be in that "EQ" option
Take a beer on me :)
geposted Mon 15 Jun 09 @ 8:43 am
I never tried Bulgarian beers, but I'm sure I would enjoy them ;-)
geposted Mon 15 Jun 09 @ 9:47 am
