I've noticed in testing that, if key_lock is on (using momentary push of beat lock button on RMX - NOT holding the button to cause beatlock to come on), pitch is adjusted downward (i/e slower), then pitch reset is pressed, the track makes some awful noise while it's ramping back up to pitch.
The issue does not happen with key_lock inactive. In that case, the transition is smooth.
I am set on fastest performance in a tweaked configuration, with simple algorithms, just as I was in 5.x, which worked without trouble. Is anyone else having this problem?
geposted Sat 13 Jun 09 @ 2:37 pm
