Forum: VirtualDJ Skins
Topic: oldschool skin and VDJ 6 problem
I am trying a few skins but I noted in "oldschool skin" VDJ doesn't support this code anymore?
visual chan="2" type="custom" factor="1.7" source="vumeterleft"
size width="12" height="118"/
pos x="782" y="167"/
down x="319" y="1683" nb="22"/
/visual
visual chan="2" type="custom" factor="1.7" source="vumeterright"
pos x="796" y="167"/
/visual
This is the skin:
https://virtualdj.com/addons/2589/OldSchool_variations.html
geposted Mon 15 Jun 09 @ 1:55 am
I have been trying to figure out a way of doing this using the "factor" but i can't work it out.
these actions are replaced with "get level_left" and "get level_right" in VDJ 6.
Jeremk,
does the "FACTOR" tag still work though?
I think it does, not sure.
hello
I have same the concern for considering bill of quantities but on the new school I seek: p
I tested as in lower part and that still does not function
Quote :
<visual deck="1" type="custom" factor="2" source="deck 1 get level_left">
<size width="12" height="118"/>
<pos x="750" y="167"/>
<down x="319" y="1683" nb="21"/>
</visual>
<visual deck="1" type="custom" factor="2" source="deck 1 get level_right">
<pos x="764" y="167"/>
</visual>
<visual deck="2" type="custom" factor="2" source="deck 2 get level_left">
<pos x="782" y="167"/>
</visual>
<visual deck="2" type="custom" factor="2" source="deck 2 get level_right">
<pos x="796" y="167"/>
</visual>
an idea?
Having spoken to CSTOLL about this and doing quite a few tests myself. It would appear that the "FACTOR" function present in V5 has been overlooked in V6.
Hopefully this might be rectified with the next update =)
I succeeded has to remake functioned considering-mêtre but it functions as on the version 1.xx has 3.xx in which is already not badly: p
here that I made :
visual deck="1" type="custom" source="deck 1 get level_left">
</visual>
<visual deck="1" type="custom" source="deck 1 get level_right">
</visual>
<visual deck="2" type="custom" source="deck 2 get level_left">
</visual>
<visual deck="2" type="custom" source="deck 2 get level_right">
</visual>
I tried your code but the vumeters seem to be the same..they apper like no stereo sound.
yes it stays Factor which prevented operation but the modulation meter is into mono
Quote :
it should be waited until the function “factor” refonctionne in the next update (I think)
i have 6.0 and it works with the old svhool skin fine nothin hapening wierd or something
