guys im looking for a mac device for playing video from my mac.looking for just normal video connection ie yellow cable not hdmi thanks guys
geposted Mon 15 Jun 09 @ 4:00 pm
which Mac do you have?? Display connection etc??
geposted Mon 15 Jun 09 @ 4:21 pm
Model Name: MacBook
Model Identifier: MacBook4,1
Processor Name: Intel Core 2 Duo
Processor Speed: 2.4 GHz
Number Of Processors: 1
Total Number Of Cores: 2
L2 Cache: 3 MB
Memory: 2 GB
Bus Speed: 800 MHz
Boot ROM Version: MB41.00C1.B00
SMC Version (system): 1.31f0
Serial Number (system): W881567Y0P2
Sudden Motion Sensor:
State: Enabled
is this what your looking for mate
geposted Tue 16 Jun 09 @ 3:05 pm
http://store.apple.com/us/product/M9319G/A?fnode=MTY1NDA3Ng&mco=MjE0ODUwMg&s=topSellers
is this the adaptor i need guys
geposted Tue 16 Jun 09 @ 4:09 pm
We need to know what video output your Mac has - DVI, Mini DVI, Mini DisplayPort? The new Unibody MB's and MBP's use the Mini DisplayPort, in which case there isn't a great solution available for Video Out via Composite or S-Video. If you have an older Mac with the DVI or Mini DVI output, Apple offers connectors for both formats to Composite Video.
geposted Wed 17 Jun 09 @ 2:18 am
My MacBook has the same specs, so I assume you have the white polycarbonate shell MacBook that is roughly a year old?
If yes, in that case the adaptor you asked is the right one (Mini-DVI --> Video). I have the same one and it works fine with VDJ.
geposted Wed 17 Jun 09 @ 4:03 am
thanks guys yes but mine is black and think its mini dvi to video i need.
geposted Wed 17 Jun 09 @ 12:36 pm
Hello,
I Also have the same setup and my question is I will be able to see full video out on the my tv or what I see on the laptop screen is what is going to show on the tv?
Thanks,
Thanks,
geposted Fri 28 Aug 09 @ 7:29 pm
