I've been running a Maya44 USB sound card with the ASIO driver and the buffer size set to Rapid. My HDD was a 40GB IDE, which was obviously not big enough.
So I upgraded to a 500GB SATA drive, installed all the software and set all the settings as they were before.
Now, I get a regular popping on the sound. It seems worse when I move the mouse. I can get rid of it by opening up the buffer size in the ASIO driver control panel, except when I'm looping, but it worries me that something that worked fine before has started causing trouble.
geposted Tue 16 Jun 09 @ 7:05 am
Do a search on the forums for more information...This topic has come up several times recently.
geposted Wed 17 Jun 09 @ 11:11 pm
Check your video card settings.
https://virtualdj.com/forums/111238/PC_Version_Technical_Support/popping_noise________.html
Robert
Robert
geposted Fri 17 Jul 09 @ 12:47 am
have you got the safe mode box ticked on the audio settings, thats usually what causes it for me
geposted Fri 17 Jul 09 @ 4:13 am
