I am on a Mac Book Pro, and i used to be able to load Virtual dj fine, but last weekend, in the middle of a gig, Virtual Dj shut down. I tried to reload it, but it would get to "initializing graphics engine..." ,stop loading, and would say "The application virtualdj quit unexpectedly. Mac OS X and other applications are not affected."
Does anyone know what's going on??
geposted Wed 17 Jun 09 @ 1:49 am
I just got the same problem. Luckily not during a gig, but I have 2 gig's this weekend, and I pray that everything is OK by tomorrow. I'll try to reinstall the software, I'll hope that solves the problems.
Mario
Mario
geposted Thu 18 Jun 09 @ 12:25 pm
Try this: delete you're preference files of vdj in the user library.
path: user/library/preferences/com.atomixproductions.virtualdj.plist
Start vdj and it will make a new preference file
All your settings are gone. you must also enter your serial.
Hopefully this will help.
MAC RULES!
MAC RULES!
geposted Thu 18 Jun 09 @ 2:17 pm
it will work when you do this - turn off your wireless. turn it back on after VDJ loads up. annoying but it works.
geposted Fri 19 Jun 09 @ 6:05 pm
I install virtualdj_pro_v6.0.1_publicbeta1 and the problem was solve. The version virtualdj_pro_v6.0.1_publicbeta2 has more problems that the first one.
geposted Sat 20 Jun 09 @ 8:23 am
Were can i download that public beta?
Can't find it?
Can't find it?
geposted Sat 20 Jun 09 @ 9:28 am
You have to own VDJ in order to have access to the public beta.
geposted Sat 20 Jun 09 @ 10:00 am
i get it to load but it wont run. I think it is due to using os 10.5.7
geposted Thu 02 Jul 09 @ 9:46 am
as said before turn off or disconnect internet then open vdj and untick netsearch that worked for me
geposted Thu 02 Jul 09 @ 5:22 pm
yeah i read to minimize your mac setup. like less animations when u do stuff, turn off bluebooth if u hav to n airport. dont run programs u need. u can use Activity monitor to see what is running. i usually every booth up close microsoft ui, adobe cue, hp updater ui, stuff i dont need at the moment
geposted Mon 28 Dec 09 @ 5:25 am
ya the same thing just happened, to me, except im on a pc. Help please! when it tries to open the scrreen freaks out
geposted Mon 17 Jan 11 @ 1:33 pm
We are now at V7, why using a V6?
The PRO User should go to their personal Download Center and install the actual Version.
https://virtualdj.com/download/updates.html
Other User should try to work with the Home Free Version.
https://virtualdj.com/download/free.html
If this Version is what you are searching for, buy it ;-)
https://virtualdj.com/buy/
Do you use the provided LE Version?
geposted Tue 18 Jan 11 @ 2:37 am
Por que no me carga algono temas mp3 el virtual 6, dice error
geposted Tue 18 Jan 11 @ 1:30 pm
MAC RULES!
MAC RULES!
This really helped and sorted out a load of my problems with VDJ. Thanks a lot for the advice.
geposted Tue 26 Jul 11 @ 3:49 pm
OK, It is a few years later now, I cant find this path path: user/library/preferences/com.atomixproductions.virtualdj.plist
with OS X 7.5 and VDJ 7.1 because I am having the crash issued, Any help?
geposted Fri 05 Oct 12 @ 2:53 pm
When VDj crash which controller your using and have you re-map the controller? and make sure your set Latency to Auto in VDj
geposted Sat 06 Oct 12 @ 1:37 pm
Please see our FAQ pages:
https://virtualdj.com/wiki/Mac%20protection%20error%20due%20to%20corrupted%20plist.html
If this doesn't help, you may need to perform a clean re-installation of the software:
https://virtualdj.com/wiki/How%20do%20I%20perform%20a%20clean%20re-installation%20of%20the%20software.html
NOTE: It's better to open a new topic rather than bump an old topic for an out-of-date version of VirtualDJ, which may no-longer be relevant with changes, bug fixes, etc. to the software since then.
geposted Sat 06 Oct 12 @ 1:44 pm
