On my MK2 when i move the crossfader over to one side it does not make it completely over on the software and it shows the fader like in a stuttering phase
I think the cross fader is dirty how do i clean it
geposted Wed 17 Jun 09 @ 10:01 am
Hi Mate.
If you can get hold of some Servisol 10 or similar switch cleaner. Squirt a little into the slider groove and work the fader over its full travel a few times to clean the track. If you are conviced its the fader and the problem comes back after a short time. Replacing the fader is the only proper fix.
Regards
Daz
Regards
Daz
geposted Wed 17 Jun 09 @ 10:19 am
