So there's this thing in Traktor 3 that is called native mix. Basically instead of recording your audio output it will record all of your midi controllers actions and save them. This is useful if you have to record the same mix on 2 different sound cards, or if you record a set and screw up at the end you can just replay the midi input and correct your mistake at the end. I'm looking for something that can do this for Virtual DJ. There must be some sort of program out there that can record midi controller input then play it back. Can anybody tell me the name of that program/plugin/etc.
geposted Wed 17 Jun 09 @ 1:56 pm
