Hello,
First of all, nice forum and great software !!...
I've downloaded the trial version and works perfect and smooth on my lappy.
However I own 2 3700's and they also work verry nice on USB and CD.
The whole midi thing is not new to me but the natively supported is.
At the moment only VDJ and DEX natively support DN-S3700 if i'm not mistaken...
Here's What I do,
1) MIDI chan 1 on both players in preset mode, (unit 1 and unit 2)
2) Both players to midi mode
3) Eneble 2nd player by using denon dj asio driver (latency 11ms)
4) Run VDJ 6.1 (trial)
5) Options / Input => none / Output => external mixer / Soundcard => Denon DJ Asio Driver
Here's my problem,
I load a song to Deck A, works great, in playmode: no delay, nice pitch/ bend/Cue/ etc...
But when i drag a song to deck B my platter stops and the player gets the info of deck B
So basicly both decks are controlled by 1 DN-S3700...
to swap between deck A and B in VDJ, I have to press 'tab' on keyboard
On the other hand the output of my 2 players works separated.
please help me out on this, Thx
greets
Here's What I do,
Here's my problem,
greets
geposted Wed 17 Jun 09 @ 3:51 pm
I have the same exact problem as well
geposted Sat 27 Jun 09 @ 7:53 pm
@Deejay G and dandi_satellite
You've done everything right so far, however you are missing one step. Under your sound card option, you need to select 2 cards (one for each of your players). I've got the same players, and it works perfectly.
Regards,
R&B Soundcrew
Regards,
R&B Soundcrew
geposted Thu 22 Jul 10 @ 12:59 am
That information is incorrect.
You do NOT want the two card option you want it set up the way you had it in asio with the Denon asio selection in the sound card box.
It sounds like you only have one card enabled.
Start your computer.
Power up the 37's and put them into midi mode
Open the Denon asio control panel and make sure both 37's are visible and enabled with check marks next to them.
Wait 30 seconds after enabling in midi mode and THEN open vdj.
If the decks are reversed, hit the eject button to swap them.
If the sound channels are reversed, open config/sound and swap the inputs there.
These decks are not cheap, and neither is Virtual DJ unless its an illegal version.
Please make sure you register your serial numbers in your user profiles so you gain all of the benefits of ownership.
geposted Thu 22 Jul 10 @ 4:45 am
