Hi - I don't know if anyone can help me with this. I'm using a video transition, and I want to tweak the crossfader so that it literally manages the volume controls for decks A and B simultaneously - in typical crossfader manner. The reason is that using the volume controls adds the fade to black on video, so it seems better for scratching and cutting videos in and out. With crossfader in literal 'crossfader' mode, the clips don't fade in and out.
Can this be done with a script? i.e. involving two parameters/controls simultaneously?
Any help would be massively wicked!
geposted Thu 18 Jun 09 @ 3:50 am
If you just want the two level faders to operate with no crossfader movement:
param_invert & deck 1 level & param_invert & deck 2 level
When the crossfader is to the left, the level fader for deck one will be at 100% with deck two at 0%. As you move to the right, they will adjust to the opposite.
Obviously you could add the crossfader as well:
crossfader & param_invert & deck 1 level & param_invert & deck 2 level
Be aware that having a level down will obviously impact your ability to PFL with an external mixer though. You could set it up as a toggle function so the crossfader works normally until you press this key/button, then it operates as you say, then you press the button again and it sets the levels back to 100% and the crossfader operates normally :)
Regards,
Scott
Regards,
Scott
geposted Thu 18 Jun 09 @ 7:45 am
amazing!!
thanks so much. i'll give this a try...
if i could ask too.. is it possible to tweak the curve on the volume, so that, e.g. both decks are at 100% with crossfader in the middle, rather than 50%??
geposted Fri 19 Jun 09 @ 4:26 am
