Ok, so maybe I don´t understand the meaning of the new "Synchronization" function at all.
I thought it to be a way of syncing the BPM of more than 2 players. But it makes no difference for me whether I check the box or not. When using the multiinstance skin, I cannot get the 2 upper players synced with the 2 below.
Did I misinterpret what "Synchronization" is all about? Or is there some way to fix this?
geposted Thu 18 Jun 09 @ 12:37 pm
You need to make sure the Multi-instance is set in both instances. The second instance you need to go to the config and set Multi-Instance to Local as well.
geposted Thu 18 Jun 09 @ 1:28 pm
I checked it in both instances. Doesn´t work.
Any suggestions?
Any suggestions?
geposted Fri 19 Jun 09 @ 4:43 pm
No one knows anything about this?
Has anyone got 3 or more players to sync up?
geposted Tue 23 Jun 09 @ 7:13 am
No one knows about this?
I posted a ticket for tech support in june and has just gotten the first reply from them today, but nothing helpfull.
Come on VDJ!!
Come on VDJ!!
geposted Wed 02 Sep 09 @ 6:31 am
