Hello, I was thinking of buying Virtual DJ 6, and I already have a Maya 44 USB and Hercules Steel Controller.
I want to start using virtual vinyl so that I have a more "hands on" approach to mixing. Would I be able to use the Maya 44 USB, Hercules Steel, and Turntables (with Time coded vinyls) as they are? - Basically what I mean is do I now have everything that is needed to do this?
I wouldn't need to use an external mixer to route it all together would I, since im using the maya?
Much appreciated :) Thanks
geposted Fri 19 Jun 09 @ 7:55 am
Yeah you do just need pro!! :)
btw I know you got the steel but IMO I would sell that and the Maya and get a RMX and then you are asured to get up and running!!!
Good luck
Good luck
geposted Fri 19 Jun 09 @ 8:16 am
Cool thanks for the help, as long as it works properly I think im going to stick with the maya and the steel for now :). I'm such an idiot though, the company initially sent me the RMX and I informed them and swapped it for the Steel because I thought it had more features. I should have kept it though they wouldnt have noticed!!!
Also which timecoded Vinyls work the best? I'm talking about the vinyls themselves! Serato, Traktor, Virtual Vinyls? Please be honest as I do know this is a Virtual DJ Forum :p.
I've heard that the new traktor vinyls are meant to be pretty good! Let me know what you guys think :D
geposted Fri 19 Jun 09 @ 8:23 am
Depends on preference now with VDJ6 since all are supported!! :) I like to keep things uniform to a certin extent!! So I just got the Virtual Vinals but now with Vers 6 Serrato and Cue and a host of others are supported which is cool since serrato has color vinals!!! In the end its up to you!!
Good luck...
Good luck...
geposted Fri 19 Jun 09 @ 8:30 am
Thanks mate for your help :) I'm going to go with the serato coloured vinyl! And then that way if I ever do decide to move onto serato in the future I won't have to spend more cash on that as well.
Cheers man
Cheers man
geposted Fri 19 Jun 09 @ 8:34 am
It's harder to see the groove on coloured records, but then do you need to see the groove with timecode? I don't do timecode so don't know
geposted Fri 19 Jun 09 @ 8:57 am
Hey guys i got a question that i need help with.
I just set up my maya 44 usb soundcard with my turntables and mixer and i get 100% signal from my timecoded vinyls. When i play it i can only hear sound out of my headphones when i cue it up on my mixer and i get no sound coming from my speakers. My speakers are plugged in through my mixer under "Master". How can i get sound out of my speakers?
geposted Fri 14 Aug 09 @ 11:57 am
Are you using powered speaker? if not you need a amp to use passive speakers..
geposted Fri 14 Aug 09 @ 2:28 pm
