I am sure this has been asked / answered before, but I can't find the answer I am looking for.
Simple Question:
I have 2 soundcards. Can I listen to both decks at the same time on my headphones?
When I use the PFL button it is either one or the other. Is there a way to have both going simultaneously?
Many Thanks
Simple Question:
Many Thanks
geposted Fri 19 Jun 09 @ 8:37 am
so is ther no way to monitor both channels?
This seems like a massive hole in VDJ functionality??!?!?!
geposted Wed 01 Jul 09 @ 7:51 am
You can't PFL both decks at the same time unless you are using an external mixer that supports it. You can do the usual cue/mix with the function headphone_mix.
geposted Wed 01 Jul 09 @ 9:36 am
