Forum: VirtualDJ Skins
Topic: Sin design question: Video ??
One of the skins im building, i want to have a pannel with Master Video and 1 video preview.
i see in the Skin Designer that i can have 'active' deck, but im figuring that this would change the video to follow which deck is selected.
But it dosent follow this theory.
Is it indeed possible to set one video preview to follow the active deck?
geposted Fri 19 Jun 09 @ 9:21 am
I have never tried anything like that but i know what your saying.
I dont mix videos much but i thnk most mix them by audio and not really worry about what images are being cued on the active deck.
You only want to see what is currently being played and what is going to be played ... a skin with 2 displays.
this is a screen shot of the work in progress...
I think i'll have to do something with the PFL buttons.
depending on which you press, it will read the buttons and change the video preview window in the video pannel...
that could do it, but takes a bit more coding..
WOW is the master video display really that big?
I actually had an idea for a new video skin... i should show you and maybe we can work something together. I'll PM
im off to the club now, hit me up with a PM or find my MSN in EXP. forum :)
I was working on something similar .. and yes you have to use the PFL buttons ...
If you want to wade through my XML .. download the source files (gray disk) - https://virtualdj.com/addons/8090/V6_Pro_Modified.html
(the PC/MAC version is not updated with the same info, yet)
