Hi all,
In Virtual DJ 6 for MAC, I've been using the Mapper with my Hercules and it works great. Question though, due to the lack of plug-ins available for MAC as of right now, is there any way that I can combine functions and then map that action to a button on my Hercules?
For example, I'd like to be able to Loop a part of the song for 1 beat and then lower the volume to zero. I can map the Loop 1 button to my Hercules but then I'd have to manually lower the volume, is there anyway I can combine the two functions, then map that action to a button the Hercules?
Thanks!
Thanks!
geposted Fri 19 Jun 09 @ 11:43 am
I know you can do simultaneous functions by using the "&" sign between the commands, but this is not consecutive. It fires all commands at once.
geposted Fri 19 Jun 09 @ 3:38 pm
That sounds like it might work. Do you know of any function that could bring the volume to zero? I could use loop 1 &_________?
geposted Fri 19 Jun 09 @ 4:31 pm
just type 'volume' and you get all the suggestions below.
example: deck 1 loop 1 & deck 2 volume 0%
geposted Mon 22 Jun 09 @ 4:08 am
