I am using Cue version 5.2.1 on a Macbook Pro with Leopard 10.5.7. Even without my DJ console attached (but the behavior is still the same, Numark DMC2 and DJ IO), any and all tracks loaded in Cue refuse to play without either reinstalling the software or resetting to factory settings. The play button depresses, but the waveform and jog wheel both sit still.
I've searched the forum for the past hour or so and have been unable to find an appropriate answer thus far. If you have any ideas, please respond ASAP as I have a gig tonight and I'd like to solve this problem once and for all. Thanks in advance.
geposted Sat 20 Jun 09 @ 10:36 am
i have a simular issue and i beleive it has to do with os 10.5.7 cause it works fine on my non-updated mac
geposted Tue 23 Jun 09 @ 12:53 pm
maybe i am being stupid just thought i would try and help.
I have this problem, all i do to fix it, is reload the audio sound card. I.e. go to preferences (in vdj) click the audio tab and set up the audio. As soon as i re-click the sound card (my case DJ-IO) it then s all starts working fine.
maybe its something completely diff if so very sorry :)
www.DJJarman.com
www.DJJarman.com
geposted Tue 23 Jun 09 @ 2:03 pm
Thanks for the tip -- this seems to work as a fix (as does reseting to factory settings), but I'd still like to find a permanent solution if possible. This is very frustrating.
geposted Wed 24 Jun 09 @ 9:08 pm
Try this. In Application > Utilities > Audio MIDI setup
Make sure that the soundcard you are using DOES NOT appear for any of the default device (Input, Output, etc)
I have seen similar problem with a soundcard where VDJ refused to play if it was seledted as such there.
geposted Thu 25 Jun 09 @ 9:51 am
