Ok so i'm new to all this VDJ stuff and thought ok i can resize the skin to suit my screen!! So i downloaded the resizer tool opened it and now it's asking me for Input Xml. Wat the fook is that when it's at home?
Please help thanks
Chris
Please help thanks
Chris
geposted Sun 21 Jun 09 @ 10:26 am
Don't sweat it...You'll be fine. The "input xml" is the script file related to the skin that you are trying to resize, and it has the same name as the skin. However, in order to use the resizer, you need to unzip the skin file that you are going to work with. This allows you to "see" the bmp file and xml file separately. After that, it's simple. Just follow the instructions to complete the resize.
geposted Sun 21 Jun 09 @ 10:34 am
Ok champion am off to do it now!
Cheers for the help dude :-D
geposted Sun 21 Jun 09 @ 10:54 am
No biggie ;)
geposted Sun 21 Jun 09 @ 3:05 pm
Ok i've been trying for a while now and just can't do it! I'm trying to resize the SSLover Black skin to fit my screen and it keeps coming up error! What am i doing Wrong?
I want to resize it to 1366 x 768! What size skin will be able to be resized in that i've tried a cpl but i just keep getting error msg :(.
Thanks Chris
Thanks Chris
geposted Sun 21 Jun 09 @ 3:06 pm
If you are using the skin resizer, you probably should post the error message to its creator here.
Good luck with your skin; I'm sure you'll work it out :)
geposted Sun 21 Jun 09 @ 3:51 pm
