Hi,
I have an m-audio fast track ultra sound card , 2xCDJ 1000 mk3 a newmark DM2050 Mixer and i want to do the whole timecode cd thing.
Right then i've got the out of my CDJ connected to the in on my sound card channels 1+2 via rca cables with jack converters on the soundcard end. and i've got the out of my soundcard channel 1+2 going to my mixer, i open VDJ goto config selected 2 timecode/External mixer/My sound card.
All works fine i can use the pitch slider on my CDJ and it alters the pitch of the track playing in VDJ the cue/play/pause all work i can switch to vinyl mode scratch and everything works great but i've got a very loud tone/hum type sound over the top of the music.
any ideas anyone
any ideas anyone
geposted Mon 22 Jun 09 @ 1:45 pm
Are you using a power conditioner?
geposted Mon 22 Jun 09 @ 2:42 pm
i dont even know what one is so i would say no.
whats it for?
whats it for?
geposted Mon 22 Jun 09 @ 2:53 pm
is this tone/hum like a hard drive hum if so go and get some groundloops isolator from maplins or look at this link : http://www.pcdj.co.uk/shop-product-details.asp?ContentID=42 sorry to virtual dj don't has this simple ground loop for sale .
geposted Mon 22 Jun 09 @ 5:11 pm
ah right will try that, when i stop the timecode cd the hum stops if that means anything. The hum is very loud
geposted Tue 23 Jun 09 @ 4:35 am
Right then i've been doing a few tests and the hum only occurs when i use the timecode cd when i connect my cdjs my mixer and my soundcard up noramally for djing with audio cds i dont get the hum and when i connect the cdj directly into the soundcard i dont get the hum so unless im missing something here i dont think this is a ground loop problem, if anyone has any ideas let mt know
Cheers
Cheers
geposted Tue 23 Jun 09 @ 11:12 am
is it a like a humm or a EEEEEEE??? sound? if so that is the time code signal you need to lower the volume on the input side of your audio device.
geposted Tue 23 Jun 09 @ 11:43 am
You are a star m8 turned down the level in my soundcard settings and im cooking with gas. near perfect sound quality full controll of mixer and CDJ, no more burning disks for me.
Thanks.
Thanks.
geposted Tue 23 Jun 09 @ 11:58 am
Glad to help..np :)
geposted Tue 23 Jun 09 @ 1:17 pm
