When i play with Timecode vinyl's i have dropouts in the music. (Like the music stops for some milliseconds)
Playing without Timecode i don't have this problem.
I have 100 % quality in the Timecode settings so that's OK
What to do
What to do
geposted Tue 23 Jun 09 @ 2:58 pm
check your latency? also if you are running virus scan turn that off if your on a laptop disable wirerless and network connections. See if that helps you out?
geposted Wed 24 Jun 09 @ 11:31 am
Thanks. All working ok now.
geposted Fri 26 Jun 09 @ 11:46 pm
