Hey guys,
I have just installed 6.01 with the latest MK2 drivers and I am trying to figure out what sensitivity percentage should I set VDJ to if I want to spin at the same pace (scratch disabled) as it used to spin in the previous version of the software. What percentage should I set it up to. I find the default really slow and I was really used to the default setting in 5.2.1 that I would like to set it up at the exact same sensitivity.
Any ideas?
I have a gig tomorrow and would love to use the new version rather than 5.2.1.
Cheers!
Any ideas?
Cheers!
geposted Thu 25 Jun 09 @ 11:53 am
Many thanks for your reply.
I have been playing with the 'Jogwheel Sensitivity Slider' and disabled the 'Jogwheel Scratch' option underneath. However, I would like to know what was the preset sensitivity percent applied in the default of the previous version as I was used to it. And with 6.01 it feels as if it is set to a slower sensitivity by default.
I know it may sound lazy, but I have been playing tunes with that preset that I just got used to it and now I cannot get the same 'feel' when bedning the track backwards or forwards...
Also, where is that ´Vinyl Mode on and off option? I cannot seem to find it.
geposted Thu 25 Jun 09 @ 4:23 pm
