After all my testing I finally figured that the Hercules RMX and my notebook don't work well together. I did figure out that using my external notebook sound card works great but I can figure out how to use my headphones for cueing.
My notebook sound card only has one output for my speakers.
In VD6 my sound setup is:
Inputs: None
Outputs: Headphones:
Sound card: 2 Cards
I have Master: First card / Headphones: Second card
My first card is set to: SigmaTel Audio (my notebook)
My second card is set to: Hercules DJ Console RMX
I get the master mix playing on my computer but no headphones for cueing. I must be misunderstanding something.
I continue to get popping using "Sound card: DJConsole RMX" so I don't want to use the default setup. Is it possible to cue using headphones with 2-cards settings?
Inputs: None
Sound card: 2 Cards
geposted Thu 25 Jun 09 @ 11:41 pm
It is possible, but you have to know that in that mode, VDJ uses the 1st stereo channel of each soundcard. Since the headphone output on the Rmx is assigned to Output 3/4, obviously, VDJ cannot use it.
However, what make you say your notebook doesn't work well with the Rmx ? Try the following before giving up entirely on using the Rmx:
1) Apply the changes explained in this guide:
http://ts.hercules.com/faqs/eng/her_eng_00364.pdf
2) In the Rmx Control Panel, switch to ASIO audio mode, and in the ASIO tab, configure as follow:
- 44 Khz
- 16 bits
- 480 (10 ms)
3) Launch VDJ. You will probably have an ERROR IN THE SOUND DRIVER message, but this normal.
For Sound Setup, configure as follow:
- Input : None
- Output(s): Headphone
-Soundcard: DJ Console RMX, then chekc the box APPLY EQ ON EXTERNAL SOURCES, the apply
Give VDJ a run and notice if you're still having problems.
Then go the PERFORMANCE tab, and uncheck the box for SAFE MODE.
- 44 Khz
- 16 bits
- 480 (10 ms)
- Input : None
geposted Fri 26 Jun 09 @ 1:53 pm
I already followed the guide (1) yesterday. The processor setting change (SpeedStep) was the most helpful but I still get some popping and crackling. It's not as noticable as before but every now and then a big pop occurs which is noticable.
I've already tried your suggested configuration in (3) but not necessarily the ASIO settings you show (2). I'll try that tonight.
I'm using a Dell 9400 Inspiron with 2GB RAM and Windows XP (SP3).
Then I use the "2-Card" setting I see the Hercules Console as an option in the sound card selections. I assumed that that would mean I could use the card in the Hercules and plug into the output 3 and/or 4 in the back.
I'm suprised that the headphone jack on the Hercules RMX gets disabled. I would have thought you can use it to cue no matter what setting VDJ uses.
Robert
Robert
geposted Fri 26 Jun 09 @ 3:17 pm
