Is there anything special that I need to know about the mapping verbs "reverse" & "dump" in 6.01?
Pulled from the Wiki:
From my tests of these, they do not work as described.
The song is played in reverse in both cases, but I don't hear any audio, at least through my headphones (when in reverse).
Any suggestions? Does anyone else have this problem?
- reverse : play the song backward
- dump : reverse the playback direction while dump is active, then when deactivated, start again forward from where the song should have been if it had been playing forward during the dump.
geposted Fri 26 Jun 09 @ 10:24 am
Use:
"dump while_pressed"
geposted Sat 27 Jun 09 @ 5:30 am
Yeah...I'm still not getting any audio coming out of my NS7 when the tracks are played in reverse.
I have uninstalled my copy of VDJ and reinstalled it and still have the same issue.
DUMP and REVERSE produce no audio out of my system. Playing forward, the audio works fine.
Has anyone else seen these problems? Guess I should hook up my Hercules RMX to see if I still have the same problems.
Regards,
Wesley
Regards,
Wesley
geposted Mon 13 Jul 09 @ 12:09 am
Just test it using the internal sound card and some keyboard shortcuts.
geposted Mon 13 Jul 09 @ 3:51 pm
It sounds as if the track is behaving as it would with "smart scratch" enabled...
geposted Mon 13 Jul 09 @ 7:54 pm
