Hi All,
Simple poll. Bassed on your experience so far would you recommend upgrading from v5 to v6?
geposted Fri 26 Jun 09 @ 12:12 pm
Absolutely, without a doubt.
geposted Fri 26 Jun 09 @ 1:36 pm
Hell yeah!
geposted Fri 26 Jun 09 @ 1:50 pm
What's your current gear around VirtualDJ and your PC??
So I can tell you if you are the 3% that don't go to upgrade.
geposted Fri 26 Jun 09 @ 2:12 pm
Not until 6.0.2 which I hope will be soon.
Acer 9920 multimedia Laptop Vista 32 ultimate
2x 2.44ghz cpu
20inch Screen HD
4gb Ram
Nivida 8600m GT video
2x internal harddrives
HD Dvd player
On board conferencing facilities
Full remote control with handset
2x 2.44ghz cpu
20inch Screen HD
4gb Ram
HD Dvd player
geposted Fri 26 Jun 09 @ 7:36 pm
No problems on my old XP pro system.
3.4ghz P4EE
1 Gig DDR 400
ATI Radeon Sapphire X1950 Pro 8x AGP
MSI 865 PE Neo2-P
3.4ghz P4EE
1 Gig DDR 400
MSI 865 PE Neo2-P
geposted Fri 26 Jun 09 @ 8:06 pm
Except for issues with pitch reset wih keylock enabled (crackling sound), it's been fine for me thus far ;)
geposted Fri 26 Jun 09 @ 8:25 pm
Gigged with it in my nightclub residencies 3 nights per week since it came out, it's awesome!!! Go get it. :-)
geposted Fri 26 Jun 09 @ 9:39 pm
well last weekend had crashes on the friday and saturday, decided yesterday afternoon to revert back to 5 worked last night for 6 hours not one freeze or crash so will be sticking with 5 tonight as well, then if time permits through the week will try and sort out what was affecting 6, because lets face it the problem has got to be my side if the majority of users are having a great time with it.
geposted Sat 27 Jun 09 @ 4:32 am
playing 2 videos seems to take a lot of memory, which i didnt notice before in version 5.
1gb ram is not enough, even if youre running XP (which uses less ram then vista/win7)
geposted Sat 27 Jun 09 @ 10:12 am
Thanks, unfortunatley because of the related issues with 6.0.1 not recognising CD+G zipped files I am using 5.2
geposted Sat 27 Jun 09 @ 6:52 pm
another night over, no problems with 5
geposted Sat 27 Jun 09 @ 7:27 pm
chriso710 wrote :
Thanks, unfortunately because of the related issues with 6.0.1 not recognising CD+G zipped files I am using 5.2
Just is the exception for upgrade. have to wait for this fix.
geposted Sat 27 Jun 09 @ 8:54 pm
6.01 recognizes zipped files just fine... what problem are you having?
geposted Sat 27 Jun 09 @ 9:07 pm
Hi Steve
6.0.1 won't recognise all zipped cd+g files as 5.2 does. Despite changing the compression on a test file 0 to 9 6.01 fails to open them . All is fine with 5.2 .
geposted Sun 28 Jun 09 @ 6:35 am
vdj6.0.... best i have used so far... solved a lot of my issues...
only thing is that deck two timecode picth continues to slightly up and down
but the response is great...... plus it solved my deck1 problems completely (had latency problems before and would not come back to set cues correctly...)
geposted Sun 28 Jun 09 @ 8:43 am
my bcd2000 jogwheels now dont work with this new version. any ideas?
geposted Sun 28 Jun 09 @ 10:44 am
To me of course.
Yes.
Yes.
geposted Sun 28 Jun 09 @ 10:48 am
well it's been good during 6 1/2 7 hour shifts at the strip clubs plus my weekend mobile gigs
the crash while search seems to be gone .......
i still have the "tired " software problem where it doesn't load the stripe in automix
it only does it after 6 or more hours, sometimes 10 , 11 hours before it happens ...hence the tired moniker
anyway i muchly dig the new default skin , and seems more stable than 5.2 plus some cool new features like netsearch .....
geposted Sun 28 Jun 09 @ 3:39 pm
i hate to say it but EVERY time i have used it in a live club setting it didn't perform as well as CUE 5.2 now mind you i scratch a bit, doubles, etc so i'm talking more on the TC issues and a few other minor things i have noticed. i did have it crash a few times while testing it out in the studio but never bother to submit the crash report. it said in there something like crash guard: serato output which doesnt make sense to me. for now i'll stick with CUE 5.2.
geposted Sun 28 Jun 09 @ 7:04 pm
