Topic: verion 6 shortcuts
wat di bumbo raas claat a gwaan wid dis new version yah...me cah get none a di short cut dem fi wuk rite.
TRANSLATION... i love the new version but i seem to be having a little difficulty with the short cuts. can anyone help me?.....................
1...make the space bar do three things at once...effects reset...volume max and play from cue.
2...clone the decks and keep the songs in sync but not locked with one press of a button( i use the c button)
don't tell me it can't be done. i did it with 5.
I know i am not the only one having issues with keyboard shortcuts but i know we can help each other.......HERE IS A NEAT PROGRAM TO HAVE..It's called SHARPKEYS..you can do alot with it if you use the keyboard like i do for djing. check it out
IRIE MON
geposted Sun 28 Jun 09 @ 6:42 pm
So I can assume you've read the wiki page on mapping first?
https://virtualdj.com/wiki/VDJscript.html
In particular this bit:
Quote :
Macros
If you need to write more complex macros, you can use the operator "&" to chain commands, or the operators "?" and ":" to write conditional branching.
Using "command1 & command2 & command3" will execute the command1, then execute the command2, then command3.
I don't know what you mean by effect reset though; by default effects are reset on load.
As for the clone decks, well the command is clone_deck. This will clone the deck and keep the pitch the same, but they won't be beatlocked unless you enable beatlock.
play a song on deck 1 for about 5 seconds then press backspin effect. the deck will still be playing but no audio.lets say the entire lenght of the back spin is about 3 seconds now stop and restart the same deck before the backspin effect finishes. as soon as the song reaches where the backspin was activated it will backspin again....not just the backspin effect but any other effect that did not finish its cycle. hope you get what i am saying.
