When you have the master volume low, to leave some headroom for later that evening.
And you play a sample it will blast out of the speakers.
I was expecting it to be running through the mixer and pass through the master volume control so it will be in relation to the music you are playing.
I am using Hercules RMX and active speakers JBL EON.
freek
freek
geposted Tue 30 Jun 09 @ 2:16 am
I am having the same problem but no one seems to be able to help with that. the sample sounds so low.
geposted Thu 24 Sep 09 @ 11:33 am
yes me to i cant seem to figure it out
geposted Sat 30 Oct 10 @ 12:30 am
If you put the samples on there own channel your good to go. I don't use a remix but I think its only 2channels so what you want wont work.
Huey
Huey
geposted Sat 30 Oct 10 @ 12:42 am
in advanced confeg you could output the sampler to 1$2 or 3&4 and it does switch so if you set the sampler to 1&2 you should be able to control the volume of the sampler sence you are able to cotrol the players is as if the sampler is a sepret program from vdj7 thire is defently somthing wrong.
geposted Sat 30 Oct 10 @ 1:17 am
any way what ever you use to control the master volume in the mapperer inter this "sampler 1 volume & sampler 2 volume & sampler 3 volume & sampler 4 volume & sampler 5 volume & sampler 6 volume & sampler 7 volume & sampler 8 volume & sampler 9 volume & sampler 10 volume & sampler 11 volume & sampler 12 volume & master_volume" instead of just "master_volume" so you will drag down all the sampels that are playing when you intend to lower the master volume
geposted Sat 30 Oct 10 @ 2:39 am
