Hi I am testing the Virtual DJ 6, I have a korg nano kontrol midi controller, and it works with abelton perfectly.
I want to assign effects for each slider, first 2 works but 3rd one and the rest doesn't work at all.
what I do is I assigned action scripts for each slider and buttons like below.
for the sliders
deck 1 effect 1 slider 1
deck 1 effect 1 slider 2
deck 1 effect 2 slider 1
deck 1 effect 2 slider 2
deck 1 effect 3 slider 1 (doesn't work)
deck 1 effect 3 slider 2 (doesn't work)
deck 1 effect 4 slider 1 (doesn't work)
deck 1 effect 4 slider 2 (doesn't work)
for the buttons
deck 1 effect 1 active toggle
deck 1 effect 2 active toggle
deck 1 effect 3 active toggle (doesn't work)
deck 1 effect 4 active toggle (doesn't work)
I made the same settings for deck 2, same issue repeats.
it's weird, these kind of setting works perfectly with serato but I like virtual dj better so, if these slider works I am all set.
I hope there is a way.
please help. thank you.
for the sliders
for the buttons
geposted Tue 30 Jun 09 @ 4:32 pm
I think I found what it is, it looks like you can only control 3 effects slider at a time. 4, 5 or 6 channelsa are only works like on/off a you can't modify the wet/dry or mod.
so I assign 3 effects with sliders and others are just on and off.
so Virtual dj guys should add control on every single effects, and get a better effect layout so you can quickly assign effects on each midi knobs.
also there should be a another quick shortcut for switch between file browsing mode to spinning mode or something, this file browsing screen is too small.
geposted Fri 03 Jul 09 @ 6:59 pm
thank you
geposted Sat 04 Jul 09 @ 9:47 am
