Hey,
This is one problem I have not been able to figure out with the new virtual dj software. Using the script you can set keyboard shortcuts for killing bass, med, or treble, however I have not been able to figure out a way of assigning separate shortcut keys for each deck, so for example I can kill the bass of one deck and kick in the bass of deck 2 at the same time, instead of having to shift from deck 1 to deck 2 and then using the same keyboard shortcut. Any ideas?
geposted Tue 30 Jun 09 @ 5:06 pm
You can control a specific deck by prefixing commands with "deck 1" or "deck 2".
geposted Tue 30 Jun 09 @ 5:26 pm
