I have tried using the keychange effect to change the key of a karaoke song for singers. Unfortunately, it does not seem to work and makes a crackling sound.
Thanks,
iamwally
Thanks,
iamwally
geposted Thu 02 Jul 09 @ 11:25 pm
You don't need a plugin; VDJ has key detection and manipulation built in.
geposted Fri 03 Jul 09 @ 4:31 am
I didn't say plugin I said keychange effect. It is an effect isn't it? Unless there is some other way that I am just missing.
Thanks,
John
Thanks,
John
geposted Fri 03 Jul 09 @ 7:58 am
Ok you can call me an idiot. I kept trying to use the keychange effect and never noticed the "key" knob right on the mixer panel. Duh!! Sorry. Don't I feel like an idiot! Oh well! Sometimes the most obvious thing is the thing we overlook!
Thanks,
John
Thanks,
John
geposted Fri 03 Jul 09 @ 8:13 am
I was going to say - you did say plugin in your title ;)
Glad you are sorted now :)
geposted Fri 03 Jul 09 @ 11:02 am
- Topic: Does keychange plugin work? -
:P
:P
geposted Fri 03 Jul 09 @ 2:05 pm
