I am lookin an applicarion that will let Me play Karaoke files (MP3+G and files in Zip format) I would also like to play My WMV and mp3 music files from the same app, Will V DJ allow me to create seperate playlists for theses files ( are stored on external hdd ) and remember the file locations and saved playlists?
I have the trial version downloaded and I cant seem to get it to play Zip files (they dont show up in the folder when I navigate to the folder they are stored in). and I cant seem to create and save a play list
Advise please before I take he plunge.
geposted Fri 03 Jul 09 @ 8:46 am
Hi
Which version do have and are you using Vista. When you placed the Karaoke zip files in VDJ did you click the right button on the right to select Karaoke, as been known folk didn't. Also unzip one of the files and see if it plays just to check the actual file is ok.
There is a known issue with 6.0.1 not being able to open certain Karaoke zip files where as they will in 5.2.1. I am advised that the team are looking at this. It has been a pain in the ass.
geposted Fri 03 Jul 09 @ 9:01 am
I downloaded the latest trial version wasn't aware I could download other versions to try
geposted Fri 03 Jul 09 @ 1:14 pm
