i wish this could be implemented, just like Serato does, do a loop then save it in to the file (brilliant). In Serato you can save up to 9 loops per file in the xml. Also the ability to adjust the in and out of loops (not shift the whole loop like we have now).
PLEASE VDJ MAKE IT HAPPEN!!!!;)
THANK YOU..........
THANK YOU..........
geposted Fri 03 Jul 09 @ 2:42 pm
+1
good idea, even with my really old PCDJ Red 5.2, it had 20 cue points and you could use the odd/even cues to automatically load a loop with one button press. (plus rename it as a special loop).
geposted Fri 03 Jul 09 @ 3:21 pm
loop_in or loop_out with a relative parameter.
Example:
loop_out -0.01
geposted Sat 04 Jul 09 @ 12:35 pm
+1 for the ability to save manual loops.
geposted Mon 06 Jul 09 @ 3:32 am
THANK YOU..........
THANK YOU..........
+1
Syberman
geposted Mon 06 Jul 09 @ 7:21 pm
+1
geposted Tue 07 Jul 09 @ 2:15 pm
Example:
loop_out -0.01
Example:
loop_out -0.01
@ SBDJ
Could this be done now on 6.0.2?
geposted Mon 09 Nov 09 @ 7:13 pm
Yes the loop shifting can still be done :)
geposted Tue 10 Nov 09 @ 4:40 am
Thanks, i will try now and see if i can figure it out......;)
geposted Tue 10 Nov 09 @ 9:10 am
+1
geposted Mon 16 Nov 09 @ 2:58 pm
Works perfect.....now if we can save the loops in the file like serato it will be the s@#it....
geposted Sat 05 Dec 09 @ 9:10 am
+1..
geposted Sat 05 Dec 09 @ 1:46 pm
+ 1
geposted Sun 09 Jan 11 @ 10:14 pm
Love how this has been dug up, proves some people do use the search feature of the forum.
On this note, I find it quite hard to believe with all the improvements and additional features we have seen in VDJ over the last 18 months, that this hasn't made the cut.
geposted Mon 10 Jan 11 @ 4:24 pm
