I am running v6 and /or le with my hercules to a external mixer via a external soundcard(soundblaster live 24bit). What would be the best way to connect it all to produce best sound for djing cluibs or mobile events.
geposted Fri 03 Jul 09 @ 2:52 pm
First ... why are you not using the Hercules sound card ?
And unless there is a reason for the external mixer - additional hardware - CD Players, etc ... I would just use the Hercules exclusively into the club's system.
geposted Tue 07 Jul 09 @ 6:34 pm
i HAVE THE Rmx I USE mONTER CABLES
( REMEMBER THE SOUND IS ONLY AS GOOD AS THE CABLES )
mONSTER PATCH CABLES TO MY 4 LINE IN MIXER(GEMSOUND vx460) tHEN TO A COMPRESSOR BBE SONIC MAXIMIZER- BBE CROSSOVER tpX500 AMPLIFIER.
dont forget!!!!!!!!!!!!!!!!!
cABLES ARE IMPORTANT...
GUITARCENTER.COM SEARCH: MONSTER DJ : XLR
xlr CABLES trs bALANCED / RCA IS MY LAST OPTION I TRY NOT TO USE THEM AS they are low quality.
FOR gROUND LOOPS --- MONSTER POWER CONDITIONER.. TO REDUCE GROUND LOOPS./
pLUG UR LAPTOP TO A DIFFERENT POWER SOURCE ./ IT ELIMINATED MY ac GROUNDLOOPS
LABC4
LABC4
geposted Wed 08 Jul 09 @ 5:46 am
tHE PLAYBACK OF A WAVE IS 16 BIT. 44K.
eVEN WITH A 24BIT CARD.
THE AUDIO WILL OUTPUT 16BIT.
aSIO WILL MAKE THE LATENCY LOW.
wITH THE rmx I HAVE NO LATENCY PROBLEMS
4GB OF RAM VISTA
4GB OF RAM VISTA
geposted Wed 08 Jul 09 @ 5:48 am
There is SOOO much mis information out there about what cards are best, what bit rates, compression rates, sampling etc etc.
As has been mentioned, vritually all commercially available tracks are recorded at 16bit, 44.1hz, which is the standard for CD audio.
24bit audio is great for studio recording and mastering, but you really dont need it for dj output.
geposted Wed 08 Jul 09 @ 7:51 am
4GB OF RAM VISTA
4GB OF RAM VISTA
You might want to check your Caps Lock key - it seems to be sticking a bit & getting your uppercase and lowercase reversed ;-)
geposted Wed 08 Jul 09 @ 8:21 pm
Due to the fact the onboard soundcard snapped at the headphone out thanks from someone knocking it off at a show. So since had it available using it. Plus since I do everything from karaoke to private parties with varied equipment based on show type. The club's equipment is subpar other then the spkrs which is what I plug into my cd coffin's mixer
geposted Fri 10 Jul 09 @ 3:08 pm
