OK, yes i'm an idiot.. this is probably something really simple, but I cant figure it out.. LOL
What i want is;
to be able to press a key on my keyboard (lets say the 'e' key )
and everytime I press it the "clipbank" plugin swtichs to the next "ambient" video ?
thanx!
What i want is;
thanx!
geposted Fri 03 Jul 09 @ 4:35 pm
I got the first part;
I can activate/turn off the plug-in with a single key press.
Key: 'C' = video_fx_select "clipbank" & video_fx
but the next part
Key: 'E' = video_fx_button +1
just brings up the first "clipbank video" and doesnt "add one"..???
how do I get it too "move to the next selection" using a single key?
thanx!
but the next part
thanx!
geposted Fri 03 Jul 09 @ 4:42 pm
thanx!
thanx!
You can't +1 on a button like that AFAIK.
You could try a slightly more convoluted way:
cycle $clipbank 12 & var_equal $clipbank 0 ? video_fx_button 1 : var_equal $clipbank 1 ? video_fx_button 2 : var_equal $clipbank 2 ? video_fx_button 3 : var_equal $clipbank 3 ? video_fx_button 4 : var_equal $clipbank 4 ? video_fx_button 5 : var_equal $clipbank 5 ? video_fx_button 6 : var_equal $clipbank 6 ? video_fx_button 7 : var_equal $clipbank 7 ? video_fx_button 8 : var_equal $clipbank 8 ? video_fx_button 9 : var_equal $clipbank 9 ? video_fx_button 10 : var_equal $clipbank 10 ? video_fx_button 11 : var_equal $clipbank 11 ? video_fx_button 12
Might need some tweaking, but should roughly work.
geposted Sat 04 Jul 09 @ 1:00 pm
I was afraid something like that is needed.. ;-)
I'll have to try it I guess!
geposted Sun 05 Jul 09 @ 1:01 pm
How come we cant use a variable in the video_fx_button ???
we can use variables everywhere else? but not there?
but, yep the "convoluted way" does work!
thanx!
thanx!
geposted Sun 05 Jul 09 @ 3:09 pm
