Using VDJ live for the first time....worked fine at home as I tested all week. Hour into gig....deck 2 started to stutter then it crashed.
Crash Report:
Crash ID=004d475c (date=907032217, version=6.0.1 Pro, build=601, thread=Main, dump=8a0683c6, excode=c0000005 (0,61572075))
Working again tonight....have re-installed everything and have been testing it all day. Thank god I brought my regular rig. Any help would be great.
Crash Report:
geposted Sat 04 Jul 09 @ 3:31 pm
Chris I had the very same problem when I first used 6.01 but with deck one. The problem was never addressed or answered, I can only assume the team are working on these issues. I have reverted back to 5.2.1 after trying out 6.01 several times although that particular issue didn't arise on the second install. I would wait for the next update before using 6.01.
geposted Sun 05 Jul 09 @ 7:32 pm
Can you list me all the sound cards you have inside and connected to your computer?
geposted Mon 06 Jul 09 @ 5:23 am
Happened again last night!!!
Crash ID=004d475c (date=907112306, version=6.0.1 Pro, build=601, thread=Main, dump=8a0683c6, excode=c0000005 (0,6365522d))
Hercules RMX Sound Card
Conexant HD Audio
Windows XP
1.93 GB Ram
AMD Turion 64 x 2
Seagate Free Agent Go External Hard drive.
PLEASE HELP!!
Conexant HD Audio
Windows XP
1.93 GB Ram
AMD Turion 64 x 2
PLEASE HELP!!
geposted Sun 12 Jul 09 @ 7:11 am
Do you use an USB HUB?
geposted Sun 12 Jul 09 @ 7:45 am
No, I plug in directly to the laptop
geposted Sun 12 Jul 09 @ 9:13 am
bump
geposted Tue 14 Jul 09 @ 11:25 am
Can you try "DPC Latency Checker" when you use with sound the RMX on your computer
http://www.thesycon.de/eng/latency_check.shtml
geposted Tue 14 Jul 09 @ 1:33 pm
geposted Wed 15 Jul 09 @ 5:03 pm
