the default setting in the new 6.0.1 MK2 pitch bend setting is +2 / -2 , can someone please tell me how to change that +1 / -1
geposted Mon 06 Jul 09 @ 1:42 am
my guess would be with a mapper. you can change the values of just about everything ......
geposted Mon 06 Jul 09 @ 6:10 pm
Yes, I knew about the mapper thanks, I just don't know how to make the adjustments on the new version of VDJ. I guess I was'nt to clear about it.
geposted Mon 06 Jul 09 @ 8:54 pm
the adjustments on the new version of vdj will be just the same as with 5.2 if your using a mapper.
geposted Tue 07 Jul 09 @ 1:23 am
I'll check into it thanks
geposted Tue 07 Jul 09 @ 1:51 pm
Go to the Config -> Mapper tab
Select the MK2 from the drop-down
Select the PITCHBEND- / PITCHBEND+ options then in the Action box .. just change the -2 or +2 to -1 / +1
Click OK ... and try it ...
geposted Tue 07 Jul 09 @ 5:54 pm
Cstoll, I made the change in the mapper as you said and I cant figure out why when I change the pitch, it keeps changing by 2's? Its too much I dont like it that way, I want to keep it with just single increases and decreases.
How can I do this please?
geposted Thu 09 Jul 09 @ 4:37 pm
you should be able to just enter the value manually??? so you should just type +1 or -1 into the value box.. not 100% on that but im positive thats how you do it.. could someone please confirm??
geposted Thu 09 Jul 09 @ 5:34 pm
Ive tried to change the pitch level in many ways and nothing is working?? It remains working the same no matter what number I set to.
Does anyone know what's wrong with this thing? All I want to do is change the behavior in how the pitch is functioning from by ( example )
128bpm to 130bpm and I only moved the rotary one click. My setting in the mapper is set to, pitch -1 / pitch +1 this occurs only when using the Hercules MK2.
geposted Sat 11 Jul 09 @ 11:25 am
pitch +1 does not mean increase by 1bpm. Pitch in VirtualDJ v6 works in percentages, so you would be better using pitch +1.0% to change pitch in 1% increments (Course), pitch +0.5% for more finer, and pitch +0.1% for very fine adjustment.
geposted Sun 12 Jul 09 @ 1:25 pm
A little late here... but when you set this as the previous poster said... don't forget to put the 0 in front of the period.
So 0.1
not .1
So 0.1
not .1
geposted Fri 17 Jul 09 @ 8:16 pm
