When I load the backspin plugin which I love very much it works only once.But after a while when I try it again it sends virtualdj into crashguard and it has to recover.It needs to be checked out.
geposted Mon 04 Apr 05 @ 12:52 am
Strange ... I use it a lot of times without any problem.
Do you have some problems with other plugins ?
geposted Mon 04 Apr 05 @ 10:22 am
Yes and I also had that same problem with another plugin.I can't remeber the name of that plugin.Well maybe the problem is with my computer.Anyway I am gonna get a more powerfull computer to run virtualdj.Thanks
geposted Mon 04 Apr 05 @ 1:50 pm
Could you post your PC specifications ?
How much RAM do you have (512 is a min.)
geposted Wed 06 Apr 05 @ 4:26 am
Its fixed in the upcomming 2.07
Plugins will not be able to crash VDJ anymore
geposted Wed 06 Apr 05 @ 1:46 pm
Well Clax I am only have 128mb for now.But I do not have any other problems with virtualdj it's just with a few plugins.But as the support staff mentionued that it will be fixed in version 2.07.So I am looking forward for that thanks.
geposted Wed 06 Apr 05 @ 5:34 pm
I think your plugin won't still work in the new release because it will be the same plugin. It's your computer the issue!!! You are the only one in that case ;-)
I don't know what dev team did but they don't change your plugins
geposted Wed 06 Apr 05 @ 10:00 pm
try re-downloading the plugins that crash...
geposted Thu 07 Apr 05 @ 12:03 am
Ok well maybe it's my computer but I have plans to change my computer soon so it's just an small issue I was concerned about.But I just loved the backspin cause where I am from the dj use it a lot and I like it.
geposted Fri 08 Apr 05 @ 10:05 pm
I promise you it works ;-)
geposted Fri 08 Apr 05 @ 10:48 pm
