i know how to type in and look for mapped features but when i try to map different decks it won't do it. example on my korg i wanna map my knobs for each decks pitch control. when i use the mapper in vdj6 it only maps to the default deck and there is no option like in previous version to change which deck it controls. this is true with all "deck" oriented controls that i have tried to map. am i missing something?
geposted Mon 06 Jul 09 @ 1:17 pm
you have to name the decks befor the action you going to activet .
like saying ,
deck 1 loop 4
deck 2 loop 4
copy and past see if ths works if yes then work on your your midi maping.
and have and look at wiki pages https://virtualdj.com/wiki/VDJscript_verbs.html
like saying ,
deck 1 loop 4
deck 2 loop 4
geposted Mon 06 Jul 09 @ 3:55 pm
worked perfect. Thanks! i knew it was something so simple i just couldn't find the answer.
geposted Mon 06 Jul 09 @ 10:35 pm
