At the current time I am only using one turntable and a maya 44 usb sound card.
I got a brand new second edition serato vinyl got into the timecode setup and set everything up,
the auto config wont recognize the the vinyl so i used noise map and when from there.
I would get a 100% but it would drift from 100 to 80 quickly and back to 100.
The tcv controls vdj fine but the only yhting is the pitch drifts off even tho my pitch is on
zero on my turntable.
Any help will def will be appreciated !!!
- Randy
- Randy
geposted Mon 06 Jul 09 @ 8:12 pm
Hi there, this topic has been discussed here.
Hopefully something here helps of you or can help us solve this problem
geposted Tue 07 Jul 09 @ 11:12 am
