I LISTEN TO MY IPOD TO SELECT THE SONGS I WANT TO PLAY ON MY NEXT PARTY..
But itune wont let me export the ON THE GO 1 On the go 2 Play lists..
After researching......
http://www.yamipod.com/main/modules/downloads/
Its YamiPod for Windows
Select Export Playlist.
>>select On the Go 1 ( or the playlist on the ipod wishing to export)
select the Folder witch the songs are in( c:\%%%%\users:\mymusic)
Then DESTINATION the VDJ Playlist folder.......
It takes some time on alot of files.. I have 10,000 Songs Took about 4min. to complete the list.
Open VDJ and on the playlist TAb .
Is On tHE GO 1..*(from the IpOD)
ready to drag and drop ANd fire the party Up..
geposted Tue 07 Jul 09 @ 10:28 pm
Wicked, this sounds like what i have been looking for.
What is the costs for the software?
cheers
Iain
cheers
Iain
geposted Wed 08 Jul 09 @ 1:20 am
cheers
Iain
iTS FREE download the software with limewire or any torrent ..
its GREAT FOR ON THE GO PLAYLIST DOING
aND PLAYING THE SAME PLAYLIST ON Vdj
cheers
Iain
geposted Wed 08 Jul 09 @ 5:10 am
I've been playing around with VDJ 6 and wondered if there was a user manual somewhere. I ran into a small problem when both players sync'ed the key to the right player. I have since locked them both so they don't change but being able to look it up might have been easier. Thanx
FMB
FMB
geposted Wed 08 Jul 09 @ 11:07 am
https://virtualdj.com/images/pdf/VirtualDJ6-UserGuide.pdf
You'll also find the user guide installed in the My Documents/VirtualDJ folder after installation ;-)
geposted Wed 08 Jul 09 @ 3:24 pm
