Gang -
Is there a utility to take a M3U list and copy the tracks to a different location?
Here is why...
VDJ (and others) create M3U playlists for - what else? playlist and history logging.
Well, after an event, I would like to have the means to 'export' that M3U file to a directory of my choice and have the ability to skip over invalid entries.
When I compiled my 2008 tracks played, I wanted the ability to copy every track from 2008 to a DVD - and make that my 'go to emergency' backup.
Trying to convert M3U to a batch file and copy does not work as in batch mode, any non letter character gets mis-translated and as a result, won't copy.
Thanks gang!
Here is why...
Thanks gang!
geposted Wed 08 Jul 09 @ 9:27 am
I would like that very much too. But until Dev Team includes this to an update, you could do what i do for now...
Click on a playlist on the left corner of the browser. Click on one of the files included in the middle (files) browser section. Press Crtl+A to select all files in the playlist. Right click ->File Operations -> Copy to (select the destination).
Hope that helped.
Hope that helped.
geposted Wed 08 Jul 09 @ 11:20 am
Thanks bud!
That would even be better.
I can backup each event to a CD for safe storage - just after the gig.
And I could make an audio CD of the important tracks just prior.
This should be a sticky or at least in the FAQ.
geposted Wed 08 Jul 09 @ 3:35 pm
Media Monkey allows you to do this. I use Media Monkey to create my playlists before a gig. Then I have Media Monkey burn a CD or DVD of the playlist and it includes all of the tracks that I can use in an emergency if VDJ or the laptop craps out. Then I export the playlist as a .m3u that I can then open up in VDJ.
geposted Sat 11 Jul 09 @ 9:28 pm
