I see on the "Hardware Recommendations" that the Denon DNS-3700 is listed. Does this represent a native, plug and play type installation? I'm also using the Pioneer DJM800 Mixer which is listed as a recommended mixer... Does the same type of plug & play apply? Just want to get a confirmation before placing the order! First time using a software in combo with decks and mixers! Thanks fellow DJ's!
AJ After Hours
AJ After Hours
geposted Wed 08 Jul 09 @ 3:21 pm
Yes, the 3700's are native now with 6.0.1. The DJM-800 is a MIDI-controller so it can be mapped, I have one but I haven't found a need to map it. Has anyone here written a mapper for it?
Have you considered the Pioneer CDJ-400's? What is it about the Denon DN-S3700's that you like? I researched both and the CDJ's came out on top so I bought them to compliment my DJM-800. I'm just curious what you came up with.
DJ RuDe
DJ RuDe
geposted Wed 08 Jul 09 @ 4:16 pm
Because the DJM-800 requires a additional MIDI interface to connect to a PC (it's not USB MIDI by default) it is hard to build a specific definition for the controller. And since the mixer really only sends info and doesn't require VirtualDJ to talk back to it ... the Simple MIDI mapper in VirtualDJ should satisfy the need.
geposted Wed 08 Jul 09 @ 6:35 pm
I use a M-Audio Uno, though it's connected I haven't mapped it
geposted Wed 08 Jul 09 @ 11:43 pm
