So in 5.2 you could load a track in using TCCDs and it would just play from the start - with 6.0 it plays from the point on the TCCD - so if the TCCD is at 6 minutes in, it goes to 6 minutes into the song - which means the song is over. This is a problem. Is there a way to fix it?
geposted Thu 09 Jul 09 @ 1:55 pm
Do you use the absolute mode ?
geposted Thu 09 Jul 09 @ 2:36 pm
No, i was using the relative + smart.
geposted Thu 16 Jul 09 @ 8:11 pm
Check the lead time in the Tc options/debug
If this is set to 0 (wich i recommend in some cases) you loose the ability to play a track from the start.
Try the default 500ms and play the timecode from the beginning.
Now your song should play from beginning too.
If this is not the case, then you probably have not a good timecode signal quality.
So in this case check cables and anything.
geposted Sat 18 Jul 09 @ 9:13 am
