Hi Guys
Lost VDJ on the display restarted and then later received crash of death screen, clicked on recover, it didn't so restrted VDJ .
No external devices being used
Crash ID=75fbe581 (date=907092050, version=5.2.1 Pro, build=521, thread=Main, dump=66833800, excode=c0000005 (0,afa335b))
Crash ID=00478519 (date=907092051, version=5.2.1 Pro, build=521, thread=Main, dump=8b484c8b, excode=c0000005 (0,4c))
geposted Fri 10 Jul 09 @ 3:10 am
I have a doubt.
Are you using Antivirus Kaspersky 2009 ?
geposted Fri 10 Jul 09 @ 6:26 am
No Virus detection on the Lappy as its just used for gigging and VDJ site
geposted Fri 10 Jul 09 @ 6:28 am
My other idea is a problem of "font".
Can you tell me which skin you are using? Then we will check the xml to see the name of the fonts used and verify if you have them in Windows.
geposted Fri 10 Jul 09 @ 6:33 am
PCVJ version 5.0 from the VDJ skin download
By the way thank you for looking at this hicup.
geposted Fri 10 Jul 09 @ 6:37 am
Should have it in your mail box now :)
geposted Fri 10 Jul 09 @ 7:03 am
Ok check if you have the following fonts in C:\WINDOWS\Fonts
Verdana
VirtualDJ
LCD
Verdana
VirtualDJ
LCD
geposted Fri 10 Jul 09 @ 7:20 am
Yes they are all there
geposted Fri 10 Jul 09 @ 7:22 am
Cheers hopefully the issue is resolved. Once 6.0.1 is recognising all CD+G zip files i will upgrade, a lot of the other issues either don't effect me or I can work around.
geposted Fri 10 Jul 09 @ 7:38 am
DJCELL No issues tonight thanlk you for your time Friday
geposted Fri 10 Jul 09 @ 8:54 pm
