Hi I have the opportunity to purchase one of these cards.
Are they suitable for use with virtual DJ.
geposted Sat 11 Jul 09 @ 5:55 am
OK no opinions on this card so ive gone ahead and got it, its an older pro card, having 4 balanced inputs and 4 balanced outputs -10 & +4dbv.
seems compatable with directx and asio, were commonly used in pc based radio stations with not bad published specs.
I'll post my progress/problems when it arrives!
geposted Tue 14 Jul 09 @ 4:57 am
I Can Report this card Works great for non time-code appilacations
Virtual DJ SETUP
Sound Setup - OUTPUTS - External mixer - Left deck: First Card / Right deck: Second Card
- SOUND CARDS - Two Cards - 1 Antex LX44 / 1 Wave
- 1 Antex LX44 / 2 Wave
A Classic Pro Card Used as industry standard in recording studios, digital audio workstations, radio broadcast automation, webcasting, audio recording and archiving, professional entertainment systems and more.
Description
1/2 size, 32 bit PCI-based, multi-channel digital audio adapter for PC and compatible computers
4 channel in/4 channel out balanced analog I/O
Supports 4 stereo devices to/from hard drive, with arbitrary mixing of any device to any output
25 pin, male D-connectors with optional XLR cable set
20 bit A/D and D/A converters/96 dB dynamic range
Windows NT, 2000 and XP
Overview
The model LX-44 offers four analog inputs plus four outputs and can simultaneously mix four virtual devices to any output. 20 bit A/D and D/A converters are used for superior audio quality and signal resolution. Audio outputs can be configured in either balanced or unbalanced mode. Windows 95/98/NT/2000 and XP demo software and drivers are available at no charge.
Technical Specifications
20-20 kHz frequency response + 0.5 dB
Dynamic Range: 96 dB typical, 92 dB minimum
003% THD+N maximum
Selectable sample rates from 6.25 kHz to 50 Hz
Inputs: Analog line input balanced
Outputs: Analog line output balanced
Signal Processor: 60 mHz, 32 bit floating point DSP
Applications
Digital audio workstations
Radio Broadcast Automation
Webcasting
Audio recording and archiving
Professional entertainment systems
Virtual DJ SETUP
Description
Overview
003% THD+N maximum
Applications
Webcasting
geposted Sun 26 Jul 09 @ 7:59 am
